ObjectTerrain getHeigh crash while negative value
Hello
While a developer done some dirty things, we found a little "bug":
If you run this code:
ObjectTerrain terrain;
terrain = add_editor(node_load("/samples/common/terrains/terrain_1.node"));
terrain.getHeight(-10, -10)
You get a engine crash with:
Unigine fatal error
engine/framework/Terrain.cpp:3301: float Terrain::getHeight(int, int) const: Assertion: 'x >= 0 && x < size_x && y >= 0 && y < size_y && "Terrain::getHeight(): bad point coordinates"'
Shutdown
Its totally clear that this call makes no sense, but its dangerous in some situation I think.
A "return -1" would be easier to handle. :)
Greets
Manuel
but would also require permanent runtime parameter checking which might be a bad idea performance-wise. Debug-build assertion seems to be the compromise
In the view point of performance this is right.
Wrote in the meantime a little check class which catch negative values and values bigger then x, y of the terrain. (if the value is bigger it too raise a crash)
I think thats enough for our use case to be sure a crash can not happen.
