ivan.cuevas Posted October 24, 2017 Share Posted October 24, 2017 Hi, In versions previous to Unigine 2.6 we had a repository for each UnigineScript directory inside data/. With the new Unigine Editor 2, we are moving these repositories as submodules to assets/ folder. From your experince with this new version, are you including .asset files in your version control repositories? Or they should be re-generated for each working copy? Thanks, Iván. Link to comment
silent Posted October 24, 2017 Share Posted October 24, 2017 Hi Iván, All the contents of assets directory should be under version control (as well as data). In that case it will allow you to recreate whole data folder on fly inside Editor 2. From our experiense, a single repo with subfolder inside data is now less convenient, because it leads to more materials loaded on start and ofter materials / objects have conflicted names across directories. We are thinking of extending assets / data workflow by allowing to specify custom location of assets directory to make work with subfolders (subprojects) in data, but can't say what the final solution would be. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
