No damping for rigidbody
Hello
Is there an option to turn off damping of rigid bodies to simulate object movement in open space.
I'm tried change parameters in "Physics settings" Linear damp to 0 and Frozen linear velocity and in Node->Body:Rigid->LDamping
also Shapes->Friction and Restitution are set to 0
but after collision of two rigid bodies they slow down movement very fast and stop
what do I need to set to make girid bodies unstopable/?
Hi, lightmap!
Can you provide a sample with this problem? I tried to repeat what you wrote, but my objects don't stop...
Best regards,
Alexander
Thank you for reply, alexander
if objects collide with some velocity - there is no problems with dampingless movement
but if you collide objects by moving one with gizmo, collided bodies has damping anyway
I'm noticed this difference recently
Edited by lightmap
You should not move physical object with gizmos, physics will not work correctly in this case (because you are just setting new transformation matrix ignoring the physical calculations).
