honya Posted August 31, 2017 Share Posted August 31, 2017 Hi, when i get normal texture from material, it return damaged normal textures. Test scene is attached normal_atlas.rar. I have set normal texture (Darkelf_armor_m_helmet_n.dds) in material, when i read it via getImageTextureImage, i get normal_from_material.dds. The textures ares not same. Why? Thanks Honya Link to comment
silent Posted September 1, 2017 Share Posted September 1, 2017 Honya, Thanks for the test scene, I've successfully reproduced this issue and created bug in our internal bug tracker. Is damaged only normal maps and other textures are working just fine in your case? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
honya Posted September 1, 2017 Author Share Posted September 1, 2017 Hi, i check albedo, emission, shading and ambient occlusion and they look fine. Link to comment
silent Posted September 1, 2017 Share Posted September 1, 2017 As a workaround you can assign normal map texture to the albedo slot and get it from here. The thing is that texture in normal map slot has unsigned format, bat engine internally threat it like signed one (therefore you have some weird artifacts). We will see if we can find any other solutions (maybe decompress image than compress it again will also fix this behavior). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
