Scott.McNab Posted August 14, 2017 Share Posted August 14, 2017 I am trying to render into a HDR image in UnigineScript, then read the pixels out of the image. I'm using this method to set the hdr flag: viewport.renderNodeImage2D(camera, node, img, width, height, 1); When I then call img.get2D(float x, float y); I get the following error in the log: Image::get(): can't get pixel from RGB16F image Looking at the engine code, there is no case in Image.cpp where the get() method called by Image::get2D(float x,float y) handles the RGB16F image format (hence the error). I tried working around this missing case statement first converting the image to another format that is supported before reading the pixels: img.convertToFormat(IMAGE_FORMAT_RGBA32F); This works, however the generated image does not have any Alpha channel! Looking at the engine code for Viewport::renderNodeImage2D(Camera *camera,Node *node,Image &image,int width,int height,int hdr), I see this logic: int flags = Texture::FORMAT_RGBA8; if(hdr) flags = Texture::FORMAT_RGB16F; Texture *texture = engine.render->getTexture(width,height,flags); Is this a bug? Why if we enable hdr render, do we use FORMAT_RGB16F instead of FORMAT_RGBA16F? This would seem to explain the missing Alpha channel. How can I work around this? Thanks Link to comment
alterego Posted August 15, 2017 Share Posted August 15, 2017 Hi, "Is this a bug?" Yes. You need to use Texture :: FORMAT_RGBA16F if(hdr) flags = Texture::FORMAT_RGB16F; replaced by if(hdr) flags = Texture::FORMAT_RGBA16F; Or use renderNodeTexture2D (only C++)https://developer.unigine.com/en/docs/2.5/api/library/rendering/class.viewport?rlang=cpp&words=rendernodetexture2d#renderNodeTexture2D_Camera_Node_Texture_void // create_resources texture = Texture::create(); texture->create2D(width, height, Texture::FORMAT_RGBA16F, Texture::WRAP_CLAMP | Texture::FILTER_LINEAR | Texture::USAGE_RENDER); // render viewport->renderNodeTexture2D(camera, node, texture); // copy image image.clear(); texture->getImage(image); if (!engine.render->isFlipped()) image.flipY(); Link to comment
