demostenes Posted June 4, 2017 Share Posted June 4, 2017 During start: aterial.parameterSlider: can't find "diffuse_visible" parameterD3D11Shader::loadFragment(): error in "core/shaders/terrain/fragment/deferred.frag" filedefines: ,BASE_DEFERRED,BLEND_SRC_FUNC_NONE,BLEND_DEST_FUNC_NONE,MATERIAL_DETAIL,MATERIAL_ROUGHNESS,MATERIAL_NORMAL,PATCH,NUM_MATERIALS=23,NUM_LAYERS=20,NVIDIA,QUALITY_LOW,RENDER_MESH_NUM_INSTANCES=341,USE_ALPHA_FADE,USE_TAA,USE_SPECULAR_LIGHT,USE_ENVIRONMENT,USE_HAZE_SCATTERING,USE_HAZE,USE_RW_TEXTURES,USE_STORAGE_BUFFERS,USE_SSAO,OUT_GBUFFER_ALBEDO=0,OUT_GBUFFER_SHADING=1,OUT_GBUFFER_NORMAL=2,OUT_GBUFFER_MATERIAL_MASK=3,OUT_GBUFFER_VELOCITY=4,USE_GBUFFER_AO,OUT_GBUFFER_SPECULAR=g,OUT_GBUFFER_TRANSLUCENT=b,OUT_GBUFFER_MICROFIBER=a,OUT_GBUFFER_SHADING_FORMAT=float4,USE_WATER_ENV_PROBES,USE_WATER_LIGHTS,USE_SOFT_SHADOWS,SOFT_SHADOWS_HIGH,USE_OMNI_SHADOW_JITTER,USE_LERP_CASCADES,DIRECT3D11,USE_COMPUTE_SHADER,FRAGMENTD:\esq\bin\core\shaders\terrain\fragment\deferred.frag(2639,10): warning X4121: gradient-based operations must be moved out of flow control to prevent divergence. Performance may improve by using a non-gradient operation Link to comment
silent Posted June 5, 2017 Share Posted June 5, 2017 demostenes Thank you for noticing that! :) This is currently known issue: https://developer.unigine.com/forum/topic/4310-unigine-25-screen-space-ray-traced-global-illumination-vector-roads-api-landcover-data-support-superposition-demo/#entry22571 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
