cory.sharplin Posted March 28, 2011 Share Posted March 28, 2011 Hi Unigine, With terrain how can I reduce the brush size smaller than 1.00 with a terrain step size of 1.00? If I create the terrain with a step of 0.1 we have the detail required when painting the terrain but the brush is not visible (maybe bug?) Need some help as we require the ability to brush in intricate detail over level maps for footpath grime etc? One more thing I might have missed somewhere, how do we enable model snap to terrain when adding assets? Thanks again Link to comment
cory.sharplin Posted March 28, 2011 Author Share Posted March 28, 2011 FYI, terrain 0.5 step and brush 1.00 brush is very jumpy and stutters cannot paint smooth, frames over 800 so shouldn’t be an issue. To repeat issue create a blank terrain diffuse map size 4096 from the Unigine editor then attempt to paint colour onto blank terrain, brush will stutter which makes painting impossible. Link to comment
cory.sharplin Posted March 29, 2011 Author Share Posted March 29, 2011 To import a terrain correctly I need the step of 1.00 so can I please request brush size for painting in terrain be allowed to go down to 0.1 instead of the current minimum which is 1.0? Link to comment
frustum Posted March 29, 2011 Share Posted March 29, 2011 data/core/editor/editor_terrain.ui at 57 line: <hslider align="expand" width="96" min="1000" max="25000"> change to: <hslider align="expand" width="96" min="100" max="25000"> Link to comment
cory.sharplin Posted March 29, 2011 Author Share Posted March 29, 2011 data/core/editor/editor_terrain.ui at 57 line: <hslider align="expand" width="96" min="1000" max="25000"> change to: <hslider align="expand" width="96" min="100" max="25000"> Thanks, any guidance with model snap to terrain? Link to comment
frustum Posted March 29, 2011 Share Posted March 29, 2011 There is another way how to create vertex-based brush: set brush power to zero. There is no automatically heights readjust tool for terrain objects. You can use "place manually" node button for single objects (don't forget about right mouse button and mouse wheel). WorldClutter/WorldCluster can perform automatic objects placement based on density map and terrain height. Link to comment
cory.sharplin Posted March 29, 2011 Author Share Posted March 29, 2011 Thanks for the tip, would be nice to see added to the editor for fast model placement. Also, note the jumpy brush bug above if you create/build a diffuse map for terrain from editor. Link to comment
