Akshay.Patil Posted February 21, 2017 Share Posted February 21, 2017 Hello , I am writing geometry shader using UUSL, My shader works fine with opengl , but in directX it fails , because of output variable used in DirectX Suppose I do Emit Vertex in main routine like this it works in both HLSL/GLSL MAIN_GEOM_BEGIN(GEOMETRY_OUT,GEOMETRY_IN) //some code OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX END_PRIMITIVE END_GEOM But I want to create a function like CreateTriangle( int index, float offset ) { OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX OUT_POSITION = postionLHS; OUT_DATA(1). = colorABC; EMIT_VERTEX END_PRIMITIVE } MAIN_GEOM_BEGIN(GEOMETRY_OUT,GEOMETRY_IN) CreateTriangle( 0, 0.25); CreateTriangle( 1, -0.25); CreateTriangle( 2, 0.50); END_GEOM Currently OUT_POSITION is not available in HLSL shader for CreateTriangle How can i pass the output arguments to CreateTriangle Routine which works in both HLSL or GLSL ? Link to comment
silent Posted February 21, 2017 Share Posted February 21, 2017 Hi Akshay, Unfortuantely, geometry shader wrapper is not yet finished. If you need to write that function you will have to use native GLSL / HLSL language and write code twice: #ifdef DIRECT3D11 <put HLSL code here> ... #elif OPENGL <put glsl code here> ... #endif Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
