building with scons errors
these are some of the errors i get when i am trying to build from scons..... what is the problem and i get all these errors.....???
entifier 'ptr'
engine\math\MathLib.cpp(108) : error C2065: 'ptr' : undeclared identifier
engine\math\MathLib.cpp(108) : error C2065: 'edx' : undeclared identifier
engine\math\MathLib.cpp(109) : error C2143: syntax error : missing ';' before '}
ImageFile.cpp
c:\unigine source sdk\source\engine\math\MathLib.h(750) : error C4235: nonstanda
rd extension used : '__asm' keyword not supported on this architecture
c:\unigine source sdk\source\engine\math\MathLib.h(752) : error C2065: 'fld' : u
c:\unigine source sdk\source\engine\math\MathLib.h(752) : error C2146: syntax er
ror : missing ';' before identifier 'v'
ror : missing ';' before identifier 'fistp'
c:\unigine source sdk\source\engine\math\MathLib.h(753) : error C2065: 'fistp' :
c:\unigine source sdk\source\engine\math\MathLib.h(753) : error C2146: syntax er
ror : missing ';' before identifier 'i'
c:\unigine source sdk\source\engine\math\MathLib.h(753) : error C2143: syntax er
ror : missing ';' before '}'
Str.cpp
File.cpp
engine\math\MathLib.cpp(81) : error C4235: nonstandard extension used : '__asm'
engine\math\MathLib.cpp(83) : error C2065: 'fld' : undeclared identifier
engine\math\MathLib.cpp(83) : error C2146: syntax error : missing ';' before ide
ntifier 'angle'
engine\math\MathLib.cpp(84) : error C2146: syntax error : missing ';' before ide
ntifier 'fsincos'
engine\math\MathLib.cpp(84) : error C2065: 'fsincos' : undeclared identifier
ntifier 'mov'
engine\math\MathLib.cpp(84) : error C2065: 'mov' : undeclared identifier
ntifier 'edx'
engine\math\MathLib.cpp(84) : error C2065: 'edx' : undeclared identifier
engine\math\MathLib.cpp(85) : error C2146: syntax error : missing ';' before ide
ntifier 'mov'
engine\math\MathLib.cpp(85) : error C2065: 'mov' : undeclared identifier
ntifier 'ecx'
engine\math\MathLib.cpp(85) : error C2065: 'ecx' : undeclared identifier
engine\math\MathLib.cpp(86) : error C2146: syntax error : missing ';' before ide
ntifier 'fstp'
engine\math\MathLib.cpp(86) : error C2065: 'fstp' : undeclared identifier
ntifier 'dword'
engine\math\MathLib.cpp(86) : error C2065: 'dword' : undeclared identifier
ntifier 'ptr'
engine\math\MathLib.cpp(86) : error C2065: 'ptr' : undeclared identifier
engine\math\MathLib.cpp(86) : error C2065: 'ecx' : undeclared identifier
engine\math\MathLib.cpp(87) : error C2146: syntax error : missing ';' before ide
ntifier 'fstp'
engine\math\MathLib.cpp(87) : error C2065: 'fstp' : undeclared identifier
ntifier 'dword'
engine\math\MathLib.cpp(87) : error C2065: 'dword' : undeclared identifier
ntifier 'ptr'
engine\math\MathLib.cpp(87) : error C2065: 'ptr' : undeclared identifier
engine\math\MathLib.cpp(87) : error C2065: 'edx' : undeclared identifier
engine\math\MathLib.cpp(88) : error C2143: syntax error : missing ';' before '}'
engine\math\MathLib.cpp(102) : error C4235: nonstandard extension used : '__asm'
engine\math\MathLib.cpp(104) : error C2065: 'fld' : undeclared identifier
engine\math\MathLib.cpp(104) : error C2146: syntax error : missing ';' before id
entifier 'angle'
engine\math\MathLib.cpp(105) : error C2146: syntax error : missing ';' before id
entifier 'fsincos'
engine\math\MathLib.cpp(105) : error C2065: 'fsincos' : undeclared identifier
entifier 'mov'
engine\math\MathLib.cpp(105) : error C2065: 'mov' : undeclared identifier
entifier 'edx'
engine\math\MathLib.cpp(105) : error C2065: 'edx' : undeclared identifier
engine\math\MathLib.cpp(106) : error C2146: syntax error : missing ';' before id
entifier 'mov'
engine\math\MathLib.cpp(106) : error C2065: 'mov' : undeclared identifier
entifier 'ecx'
engine\math\MathLib.cpp(106) : error C2065: 'ecx' : undeclared identifier
engine\math\MathLib.cpp(107) : error C2146: syntax error : missing ';' before id
entifier 'fstp'
SimdLib.cpp
engine\framework\ImageFile.cpp(375) : fatal error C1083: Cannot open include fil
e: 'jpeglib.h': No such file or directoryengine\math\MathLib.cpp(107) : error C2
entifier 'qword'
engine\math\MathLib.cpp(107) : error C2065: 'qword' : undeclared identifier
ImageFormat.cpp
entifier 'ptr'
engine\math\MathLib.cpp(107) : error C2065: 'ptr' : undeclared identifier
engine\math\MathLib.cpp(107) : error C2065: 'ecx' : undeclared identifier
engine\math\MathLib.cpp(108) : error C2146: syntax error : missing ';' before id
entifier 'fstp'
engine\math\MathLib.cpp(108) : error C2065: 'fstp' : undeclared identifier
Generating Code...
entifier 'qword'
engine\math\MathLib.cpp(108) : error C2065: 'qword' : undeclared identifier
entifier 'ptr'
ImageFile.cpp
File.cpp
ror : missing ';' before identifier 'v'engine\framework\ImageFile.cpp(375) : fat
al error C1083: Cannot open include file: 'jpeglib.h': No such file or directory
Mesh.cpp
ImageFormat.cpp
SimdLib.cpp
Terrain.cpp
Geometry.cpp
rd extension used : '__asm' keyword not supported on this architecturec:\unigine
 source sdk\source\engine\math\MathLib.h(750) : error C4235: nonstandard extensi
ndeclared identifierc:\unigine source sdk\source\engine\math\MathLib.h(752) : er
ror : missing ';' before identifier 'fistp'c:\unigine source sdk\source\engine\m
ath\MathLib.h(752) : error C2146: syntax error : missing ';' before identifier '
v'
ath\MathLib.h(753) : error C2065: 'fistp' : undeclared identifier
ror : missing ';' before identifier 'i'c:\unigine source sdk\source\engine\math\
MathLib.h(753) : error C2146: syntax error : missing ';' before identifier 'i'
Bounds.cpp
Geometry.cpp
Stream.cpp
Bounds.cpp
Compress.cpp
Generating Code...
engine\utils\Compress.cpp(19) : fatal error C1083: Cannot open include file: 'zl
ib.h': No such file or directoryc:\unigine source sdk\source\engine\math\MathLib
Generating Code...
scons: *** [tools\TerrainMesh\build\engine\math\MathLib.obj] Error 2
Stream.cpp
Occluder.cpp
scons: *** [tools\TerrainRelax\build\engine\utils\Log.obj] Error 2
Stream.cpp
Compress.cpp
Compress.cpp
ndeclared identifierengine\utils\Compress.cpp(19) : fatal error C1083: Cannot op
en include file: 'zlib.h': No such file or directory
Timer.cpp
Generating Code...
Generating Code...
MeshFile.cpp
scons: *** [tools\Terrain\build\engine\math\MathLib.obj] Error 2
Generating Code...
scons: *** [tools\TerrainMesh\build\engine\utils\Log.obj] Error 2
scons: *** [tools\TerrainRelax\build\engine\framework\Image.obj] Error 2
Generating Code...
scons: *** [tools\Terrain\build\engine\utils\Log.obj] Error 2
Generating Code...
scons: *** [tools\Terrain\build\engine\framework\Image.obj] Error 2
scons: *** [tools\TerrainMesh\build\engine\framework\Image.obj] Error 2
scons: building terminated because of errors.
C:\Unigine source SDK\source>
Oh....this is for Unigine1 sdk.... I have had that issue for a while but now I need to figure out what the problem is....
the build.py seems to be working, can i have the arguments in order to build the engine with cuda, opencl capability with the script....? cause in two different systems i can t get scons to work... always gives me these errors that i posted above........
