Variable::mod(): bad operands double and double
Is it possible to use mod function with float numbers? I get an error: Variable::mod(): bad operands double and double.
I try round my numbers and use this function with int numbers:
	float normalRelativeAngle(float angle)
		int angleInt = round(angle * 1000);
		int pi2Int = round(PI2 * 1000);
		int result = angleInt % pi2Int;
		log.message("angleInt=" + angleInt + ", pi2Int=" + pi2Int);
		return (result / 1000.0f);
	int round(float value)
		int result;
		if (value < 0)
			result = ceil(value - 0.5);
		else
			result = floor(value + 0.5);
		return result;
I have the same error, although I convert float numbers to int number
		int result;
		if (value < 0)
		else
		return result;
Please, see the documentation articles: Programming / UnigineScript language / Operators / Numerical Operators and Programming / UnigineScript language / Core Script Library / Math Common Functions.
You have to cast result variable to int explicitly.
return int(result);
Ok... strange, in documentation about ceil says:
The type of returned value will depend on the argument type:
int for int, long, float arguments
About floor only:
Largest integer value not greater than arg.
So ceil/floor functions dont do type conversion?
Sorry, it seems that documentation in SDK is outdated:
variable ceil(variable arg)
Ceiling function that returns the smallest integral value that is not less than arg. For vectors ceiling values are obtained per component.
Arguments
variable arg - Argument. Can be the following types:
* int
* long
* float
* double
* vec3
* vec4
* dvec3
* dvec4
Return value
Smallest integer value not less than arg. The type of returned value will depend on the argument type:
* float for int, long, float arguments
* double for double arguments
* vec4 for vec4 arguments
* dvec3 for dvec3 arguments
* dvec4 for dvec4 arguments
Examples:
float a = ceil(2.3) // a = 3.0
variable floor(variable arg)
Round an argument down to the nearest integer. For vectors values are obtained per component.
Arguments
* int
* long
* float
* double
* vec3
* vec4
* dvec3
* dvec4
Return value
Largest integer value not greater than arg. The type of returned value will depend on the argument type:
Examples
float a = floor(2.3) // a = 2.0
