renato.semadeni Posted May 24, 2016 Posted May 24, 2016 Hi there I'm observing an inconsitent farclipping plane for the world in the distance. In the middle of the screen, the mountains are not shown in a certain distance, but if we turn left or right they become visible (with the same distances as before). Kind regards, Renato
silent Posted May 24, 2016 Posted May 24, 2016 Hi Renato, General recommendation for Far clipping / Scattering tuning is to set up scattering max distance (Rendering Settings -> Environment -> Max distance) equals to camera's far clipping plane. Not sure, however, if it will help in your case. Probably, you will need to increase Far clipping parameter a bit (for example, 10000 -> 10015) to avoid such visual artifcats). Small test scene will be very helpful in this case. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
renato.semadeni Posted May 26, 2016 Author Posted May 26, 2016 Hi Andrey As I can see it now, this solves our problem so far! Thanks a lot
