demostenes Posted May 15, 2016 Share Posted May 15, 2016 We are experiencing strange behavior while using transformation tools and object duplication together(shift + move for example). Take a look at the captured video at http://take.ms/hiS7GIt happens when you change the rotation of object and the Local pivot Z axis is parallel with the X axis of World pivot(rotation of object along Y axis by 90 degrees).1) Take some node from your library2) Rotate it along the World Y axis by 90 degree. Make sure that the Local pivot Z axis is parallel with World X axis3) Duplicate object4) Add first object to selection5) Duplicate + move (shift + move) object somewhereYou can see in the node information tool (I) that the coordinates of "center" are changing. For some type of nodes it is really small number and the problem is not noticeable at the first sight. Link to comment
grmmvv Posted May 16, 2016 Share Posted May 16, 2016 Hi, Thank you for the detailed description. I've successfully reproduced this issue and added bug to our internal bug tracker. Link to comment
grmmvv Posted June 16, 2016 Share Posted June 16, 2016 Fixed, will be available in the next SDK update. 1 Link to comment
radek Posted December 7, 2016 Share Posted December 7, 2016 Hello, I think that we have similar problem again. Pls take a look at this video: https://youtu.be/UfZjcar-jH4 Reproduction steps: 1) Switch to local coordinate system 2) Import some node (or create primitive) 3) a ) Rotate it -90 deg (counter clockwise) b ) Rotate it 90 deg (clockwise) 4) a ) Duplicate + move (shift+move and hold the LMB for some time) in X direction (positive or negative) b ) Duplicate + move (shift+move and hold the LMB for some time) in Y direction (positive or negative) Link to comment
grmmvv Posted December 9, 2016 Share Posted December 9, 2016 Hi,Thank you for detailed description, but unfortunately I can't reproduce this issue.So we need some additional information about this problem: * at the video, I see lag when you making clone of the node. Is this engine lag or this is video problem? * you wrote that this issue can reproduce on engine primitive, but I need some clarifying: did you had any physics at NodeReference from video? * which precision of binaries did you use: double or float? * can you reproduce this issue on minimal test scene (new world and one node)? Or this problem appears only in heavy worlds with a complex hierarchy? Link to comment
radek Posted December 9, 2016 Share Posted December 9, 2016 Hi, * at the video, I see lag when you making clone of the node. Is this engine lag or this is video problem?This lag is in editor. Heavy scene, but not all the objects are loaded and visible at the time. Video is ok (except the badly set bitrate for 1080p60) * you wrote that this issue can reproduce on engine primitive, but I need some clarifying: did you had any physics at NodeReference from video?No, these referenced nodes are just a MeshStaticObjects with several surfaces and without any physics. * which precision of binaries did you use: double or float?float * can you reproduce this issue on minimal test scene (new world and one node)? Or this problem appears only in heavy worlds with a complex hierarchy?I've tried to reproduce it on minimal test scene right know and the problem did not appears. On small scene with ~200 objects(static) is the problem barely visible, if I look under the cursor, I can see that the position is incrementing/decrementing by 0.001. On heavy scene, like the one in video, it's noticeable immediately. Link to comment
demostenes Posted December 9, 2016 Author Share Posted December 9, 2016 * at the video, I see lag when you making clone of the node. Is this engine lag or this is video problem? Generally if you have lots of nodes in the scene, any operation with node lags. Adding, deleting, cloning, editing node reference...I think this is other manifestation: https://developer.unigine.com/forum/topic/4110-world-layer-lag/ Link to comment
grmmvv Posted December 12, 2016 Share Posted December 12, 2016 Hi, Thank you for your information! I've successfully reproduced this issue and added bug to our internal bug tracker. 1 Link to comment
m.c. Posted February 16, 2017 Share Posted February 16, 2017 Hello, problem is still present in abundant scenes. - even with non-duplicated nodes - after rotation Link to comment
demostenes Posted May 10, 2017 Author Share Posted May 10, 2017 Any progress? It creates significant overhead for level designers... Link to comment
silent Posted May 10, 2017 Share Posted May 10, 2017 Hi Jirka, Are still having this in 2.4.1? We can' reproduce it on a simple scene like pbr_materialballs when we move all the objects at (x: 5000, y: 5000, z: 500). Also, could you please specify the pivot point and coordinate system for such objects? Are you using double precision builds for your large areas? Float precision binaries can give you unpredictable results on large distances, but we still can't reproduce it even for float binaries. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
demostenes Posted May 10, 2017 Author Share Posted May 10, 2017 We are using float and not big distances. The biggest possible distance is 12000 (terrain size is 12k*12k), but mostly it is between 2000-10000. I think it depends on the number of objects in the scene. Now we have many thousands objects in the world. Most of it is in world layer node, but still some are loaded. Link to comment
werner.poetzelberger Posted May 15, 2017 Share Posted May 15, 2017 We had somehow a similar issue. It is some kind of calculation error, which can add up when you do transformations from different coordinate systems. Link to comment
