ExBemined Posted April 1, 2016 Share Posted April 1, 2016 When I enable logarithmic depth, ObjectGui has some rendering issues in Unigine 2.2. In our case the ObjectGui shows in front of objects even though it is placed behind it. When I tried to reproduce in the ObjectGui sample I got different results but it was broken as well. Simply enable logarithmic depth in the gui_00 sample and based on the camera angle weird green artifacts start showing like in the attached image. Link to comment
silent Posted April 1, 2016 Share Posted April 1, 2016 Hi Michael, Yes, this is known issue. ObjectGUI object needs to be refactored to work correctly with logarithmic depth buffer. Currently, we recommend to not use logarithmic depth with GUI objects. Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted April 6, 2016 Share Posted April 6, 2016 Hi Michael, There are two workarounds available, however (in case of gui_00 sample). object_gui material can be tuned in the following way: In case of Alpha blend (Forward) transparency preset you can turn off Depth write checkbox; OR You can also change Alpha blend (Forward) transparency preset to Opaque (Deferred). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
