a.demidenko Posted August 11, 2015 Share Posted August 11, 2015 Hi guys. I'm trying to run my own application under Linux using GLAppQt bridge sample files from your SDK. Application has been compiled and linked against Unigine RC-2.0. i'm getting the following error "GLExt::init(): GL_ARB_buffer_storage is not supported". Hence seems like RC-2.0 has been built using USE_OPENGL_44 flag which enables requirement of ARB buffer. Can you please suggest any workaround to this problem? Link to comment
silent Posted August 12, 2015 Share Posted August 12, 2015 Hi Alexander, What GPU are you using? Please, make sure that you have installed latest GPU drivers. Also, please check if your system meets a minimum hardware requirements for Unigine 2.0: https://developer.unigine.com/en/docs/1.0/start/hardware#gpu(if you are using Linux, only proprietary drivers are supported). Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
