ataylor Posted July 29, 2015 Share Posted July 29, 2015 See attached test scene. Uncomment lines 33 & 34 to view problem. WidgetSpriteViewport is a child of hpaned and can be resized. When WidgetSpriteViewport is resized, I want to also resize its texture to avoid scaling artifacts. After I call setTextureWidth or setTextureHeight on WidgetSpriteViewport object, I get a crash in engine in WidgetSprite::render(), WidgetSprite.cpp:332 What am I doing incorrectly? test.cpp test.ui test.world Link to comment
maxi Posted July 30, 2015 Share Posted July 30, 2015 Hi, Adam, Thanks for your post, there was a bug in WidgetSpriteViewport, it will be fixed in next release. If you can rebuild engine, add "setRender(NULL);" to the end of methods void WidgetSpriteViewport::setTextureWidth() and void WidgetSpriteViewport::setTextureHeight() to fix this. As for your code: remove "viewportHolder.widget.addChild(gViewport.m_viewport, ALIGN_EXPAND)", because you have already done this in "m_parent.addChild(m_viewport,...)". Link to comment
ataylor Posted July 30, 2015 Author Share Posted July 30, 2015 Thank you maxi. I removed the superfluous addChild call (thanks for catching that!), and the engine no longer crashes with the setRender(NULL) C++ calls in place. I may still need help getting this to behave the way I need. I will experiment with it some more and post again if I need further assistance. Link to comment
