cinetec_tech Posted June 30, 2015 Share Posted June 30, 2015 hi: Currently i need create a temporary material and assign to a object. But the setMaterial method only allow use string as material name in the library is there anyway to use material directly? thanks Link to comment
unclebob Posted July 1, 2015 Share Posted July 1, 2015 Hi Cinetec! Unfortunately, there's no way you can assign Material instance directly, so if you want to create temp material them you'll have to assign it by its name. Another way of solving your task could be getMaterialInherit function which will create a new material instance inside which will be inherited from currently assigned material. Then you can do everything you want with that material. Link to comment
