Tu.Xiaomi Posted January 26, 2015 Share Posted January 26, 2015 When I had completed my work, saving world. tips.It is a huge world.3072 X 3072 The next time I opened the same world, some node changed their position about 1~3cm. How to fix this. Link to comment
sebastianbah Posted January 26, 2015 Share Posted January 26, 2015 Hi, Step by step instructions will surely help us to get to the root of the problem faster. Also If it's possible, a simple test scene would be very helpful. Thanks! Link to comment
Tu.Xiaomi Posted January 28, 2015 Author Share Posted January 28, 2015 Hi, Step by step instructions will surely help us to get to the root of the problem faster. Also If it's possible, a simple test scene would be very helpful. Thanks! The model's position is over 10000.0 And when I moved the model, the unit was 1 meter, then the movement delta was 0.1 m, the modify action can't be down than 0.1 m. it was a precision problem, when the position x,y,or z was over 10000.0, the modify action that down than 0.1 m couldn't be applied, so two snapped model has space between them. Link to comment
sebastianbah Posted January 28, 2015 Share Posted January 28, 2015 If I understand you correctly, problem is that the position value is rounded to a first fractional digit on a large distances. Is it so? Link to comment
Tu.Xiaomi Posted January 30, 2015 Author Share Posted January 30, 2015 If I understand you correctly, problem is that the position value is rounded to a first fractional digit on a large distances. Is it so? position.png Yes, this is the problem. Link to comment
ulf.schroeter Posted January 30, 2015 Share Posted January 30, 2015 Sounds like floating point precision isuues, you should use Unigine double-precision build to see if this resolves the problem. Link to comment
silent Posted February 2, 2015 Share Posted February 2, 2015 Hi, We found the root cause of this behavior. Unfortunately, float and double versions are both affected. Bug fix would be available in the next SDK update. Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted February 26, 2015 Share Posted February 26, 2015 This bug is fixed in Unigine 2.0-beta. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
