renato.semadeni Posted January 20, 2015 Share Posted January 20, 2015 Hi there We have a test area build up as a landscape. Now we try to flatten out specific areas to position some larger objects, as airports, runways, ... I tried it with the terrain editor tool, but nothing happens. In the docu is written that "All brushes modify only the refined arean (0-3 LODs)". Is this the problem? Do you propose another approach to flatten areas? Kind regards, Renato Link to comment
silent Posted January 20, 2015 Share Posted January 20, 2015 Hi Renato, Have you tried to adjust Min/Max height to your terrain heights values? This option means that you will be able to paint on terrain only if it is in range (Min Height; Max Height). In your case it is a range from -100 to 100. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
renato.semadeni Posted January 20, 2015 Author Share Posted January 20, 2015 Ah, yes! Sorry about that! I just tried the regulators and not to write a value into the field... :unsure: Link to comment
