[SOLVED] Terrain editor doesn't change the nodes in landscape
Hi there
We have a test area build up as a landscape. Now we try to flatten out specific areas to position some larger objects, as airports, runways, ...
I tried it with the terrain editor tool, but nothing happens. In the docu is written that "All brushes modify only the refined  arean (0-3 LODs)". Is this the problem? Do you propose another approach to flatten areas?
Kind regards,
Renato
Hi Renato,
Have you tried to adjust Min/Max height to your terrain heights values? This option means that you will be able to paint on terrain only if it is in range (Min Height; Max Height). In your case it is a range from -100 to 100.
Ah, yes! Sorry about that! I just tried the regulators and not to write a value into the field... :unsure:
