[SOLVED] Insert function body in another file
I've written a class with several functions. How can I define functions' bodies in another file ?
Class declaration is in *.h-file. I would like to create another file with class functions definitions.
For example, in C++ language - class declaration is in *.h-file, class definition is in *.cpp-file. How is it in Unigine script ?
Hi.
In Unigine script you can write function implementation in a declaration "*.h" file like this:
class Foo {
	void foo() {
		log.message(__FUNC__ + ": called\n");
And you can write implementation separately from declaration like this:
class Foo {
	void foo();
Foo::foo() {
But there is no difference between *.cpp and *.h files in Unigine script. These extensions just a formality.
See more at https://developer.unigine.com/en/docs/1.0/scripting/language/preprocessor#include
Thank you for quick answer.
Yes, I can write declaration and definition separatelly in one file.
But can I write them in two separate files ?
Hi. You can include implementation by simple #include:
// test.h file
class Foo {
	void foo();
// test.cpp file
#include <test/test.h>
void Foo::foo() {
//main.cpp file
#include <test/test.cpp>
int init() {
	Foo f = new Foo();
	f.foo();
Thank you very much!
I did all the same before, but I include test.h in main.cpp (and don't include test.cpp) - because I thought in C/C++ style.
After I've included test.cpp in main.cpp - all works correct.
Now I understand your words:
