cem.orsel Posted September 15, 2014 Share Posted September 15, 2014 Hi, previously when I opened a Unigine project, I used to be able to drag a local widget (i.e. Node Editor) out of the main project window, to view the simulation output and changes in node editor simultaneously, but all of a sudden, the editor widgets are now restricted with the main window, and I didn't make any configuration changes either (at least not on purpose). Do you know a way to fix this? (The Node Editor window was previously not bound by the main window.) Link to comment
silent Posted September 15, 2014 Share Posted September 15, 2014 Hi, This behavior occurs when Interface plugin is not loaded. Please check if Interface plugins is loaded (you can check it in the console: Loading "Interface_x64.dll"). Also, please make sure that you launch engine with -extern_plugin "Interface" command line option and Interface.dll is available from PATH or located near the *.exe file. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
cem.orsel Posted September 15, 2014 Author Share Posted September 15, 2014 Adding the command line option to .cfg file solved it. Thanks Silent. Link to comment
