Bhavikkumar.Sharda Posted September 2, 2014 Share Posted September 2, 2014 We are exploring Unigine's Webgl port since some time and facing some issue while compiling the engine. We are performing manual compilation from engine directory, setting webgl as default platform and clang as default compiler in SConstruct. First few errors are engine\math/MathLib.h:457:31: error: use of undeclared identifier '_mm_set_ss'; did you mean '_mm_set1_ps'? _mm_store_ss(&v,_mm_sqrt_ss(_mm_set_ss(v))); engine\math/MathLib.h:457:19: error: use of undeclared identifier '_mm_sqrt_ss'; did you mean '_mm_sqrt_ps'? _mm_store_ss(&v,_mm_sqrt_ss(_mm_set_ss(v))); engine\math/MathLib.h:457:3: error: use of undeclared identifier '_mm_store_ss'; did you mean '_mm_store_ps'? _mm_store_ss(&v,_mm_sqrt_ss(_mm_set_ss(v))); engine\math/MathLib.h:497:19: error: use of undeclared identifier '_mm_rcp_ss' _mm_store_ss(&v,_mm_rcp_ss(_mm_set_ss(v))); engine\math/MathLib.h:812:33: error: use of undeclared identifier '_MM_HINT_NTA' _mm_prefetch((const char*)ptr,_MM_HINT_NTA); . . . . We are unable to get these implementations in xmmintrin.h of Emscripten. Does anyone else get success in compiling Engine for WebGL platform? Which Version of Emscripten and Unigine version was used. We are having Scons version : 2.2.0 Emscripten version : 1.12/1.20/1.23 Unigine version : unigine_2014_06_04 Link to comment
Bhavikkumar.Sharda Posted September 3, 2014 Author Share Posted September 3, 2014 We tried disabling simd, which moves the compilation to next step. Now it looks like "unigine\source\engine\render\opengles" directory is missing from the full source version unigine_2014_06_04. We understand that WebGL port is currently in beta phase and not supported, but since we are in early stage of exploring the WebGL potential, we need all necessary files required to compile Unigine for WebGL platform. Link to comment
silent Posted September 3, 2014 Share Posted September 3, 2014 Hi, Please, contact us directly at engine-support@unigine.com. We will send you missing files. However, WebGL port is deprecated and it will not recieve updates in future. We are highly recommended to not use it. Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
ianyyin Posted May 25, 2015 Share Posted May 25, 2015 Hi Silent, Which unigine version contains the last working webgl version? Could you provide the missing files to us as well? Thanks, Ian Link to comment
silent Posted May 25, 2015 Share Posted May 25, 2015 Hi, Please, contact us via engine-support@unigine.com. The latest stable Unigine 1 (2014-07-07) was the last one with WebGL experimental support. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
