lishengjun Posted July 10, 2014 Share Posted July 10, 2014 I want to add some videos to one ObjectGuiMesh which mesh has several surfaces, Could i make each surface with different videos? That's necessary to use ONE mesh ! thank you~ Link to comment
binstream Posted July 10, 2014 Share Posted July 10, 2014 "If the mesh contains several surfaces, the same GUI will be rendered on each of them. Note that the GUI will be rendered according to the UV mapping of surfaces." https://developer.unigine.com/en/docs/1.0/scripting/library/objects/class.objectguimesh Link to comment
zheng.guan Posted November 2, 2014 Share Posted November 2, 2014 I want to add some videos to one ObjectGuiMesh which mesh has several surfaces, Could i make each surface with different videos? That's necessary to use ONE mesh ! thank you~ Have you solve this problem? I meet the same problem! Thank you very much! Link to comment
unclebob Posted November 5, 2014 Share Posted November 5, 2014 For your tasks it's better to split that into two meshes and create two ObjectGuiMesh nodes instead of one. Link to comment
