anthony.l Posted June 18, 2014 Share Posted June 18, 2014 Here's a dumb question. How do I run the heaven-2014-06-04.ung file? I have downloaded the Game SDK and would like to run that. Thanks, Anthony Link to comment
silent Posted June 19, 2014 Share Posted June 19, 2014 Hi Anthony, You need to put this file to <SDK>/data folder. After that you can open SDK Browser and run Heaven from the Benchmarks tab. Also, you can extract contents of ung archive with Archiver tool. All you need to do is to run following command inside <SDK>/data folder: ung_x64 -e heaven-2014-06-04.ungung_x86 (if you are using x86 OS) Files will be extracted into <SDK>/data/demos/heaven directory. After that you can remove ung archive from <SDK>/data folder. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
anthony.l Posted June 19, 2014 Author Share Posted June 19, 2014 Thanks! That worked. Link to comment
