snow_zhangy Posted June 14, 2014 Share Posted June 14, 2014 is that possible to show the engine on the second monitor(not the primary monitor) in fullscreen mode 1? we need this feature. thanks Link to comment
silent Posted June 16, 2014 Share Posted June 16, 2014 Hi, Could you please give us more information about your use case: Do you want to run single engine window on secondary monitor? Do you use any App plugins? Your setup includes only two monitors (primary and secondary)? There two possible solutions: Change primary monitor in OS settings, so engine will launch on different monitor. Write custom App that will launch engine on the second monitor with fullscreen enabled. You can check generic AppWindow implementation here: source/plugins/App/common/AppWindow.cpp Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
