angus.wood Posted June 12, 2014 Share Posted June 12, 2014 I'd like it if we kept the last application log when the system was restarted. The scenario is that, should there be a problem with our Unignine-based product the customer will re-start the application and then call us to tell us about the issue. At the moment the old log is truncated on re-start so any chance of debugging is lost. My suggestion is that the old log is renamed to ".last" each time the application is run so we always have the application's log history. I think this would be pretty simple to implement. Link to comment
azagniy Posted July 10, 2014 Share Posted July 10, 2014 Hi. You can manually copy a engine log file before start engine. It can be done using shell command or in your launcher application or somewhere else. For example you can use simple Python engine launcher: #this is a python launcher code import os import shutil log_file = os.path.curdir + os.path.sep + 'log.html' last_log = os.path.curdir + os.path.sep + 'log_last.html' shutil.copy(log_file,last_log) os.system(os.path.curdir + os.path.sep + 'main ' + '-engine_log ' + log_file + ' -sound_app openal \ -data_path ../../../ -system_script core/unigine.cpp extern_plugin -Interface') Link to comment
