[SOLVED] Volume Box Falloff AA artefacts
I am working on a scene using a lot of volume boxes.
Those create the desired effect.
Everything works fine as long as I do not combine AA (in the render options) and the falloff option (in the material).
It also DOES work combo like: AA + Falloff + NO HDR
It DOES work: AA + NO Falloff + HDR
It does NOT work: AA + Falloff + HDR
The combinations seems to bring up strange render issues. Please look at the images attached.
Thx.
werner
Hi Werner,
I'm afraid we can't reproduce such behavior so it would be very helpful if you could send us Unigine log file at least.
Also a minimal test scene would be very helpful.
Dear Sebastin,
uploading a testscene atm ~ 350 mb.
Attached the startoptions.
The scene is set to a camera which is moving around the object array. The artefacts are occuring with these current settings.
Cheers
Werner
Ok, I think I come closer to that issue.
The object in the center uses a material with a GLOW.
This seems to do the damage.
Disabling the object or assigning a different material solves the render issues.
Anyway .. there seems to be a render order issue?
Best.
Werner
Hi Werner,
Sorry for the late reply.
This issue is confirmed and added to our bug tracker.
It seems that this issue actually related to the combination of glow + hdr.
Thanks for the test scene and your suggestions.
  • 8 months later...
