nat.harrold Posted March 5, 2014 Share Posted March 5, 2014 Hi, When using grabber / HDR cube map with AA max and resolutions above 1024, Unigine freezes then goes fatal. This has been long term problem for me. Wondering if anyone else has a similar problem. DX11 GTX770Ti 16GB RAM Windows 7 pro SSD Link to comment
werner.poetzelberger Posted March 6, 2014 Share Posted March 6, 2014 Isnt that grabber depending on the VRAM somehow?. We had some troubles with high res 'normal' screen grabs at 4096 resolution using a 2GB card. (at least after some shots Unigine does crash). On a 4 GB card it got better for some more grabs, but it did a crash after some more files. A cubemap 6x1024 is maybe too much for a 770Ti (2 gig Vram? or 3?) Does it work with lower res? cheers Werner Link to comment
werner.poetzelberger Posted March 10, 2014 Share Posted March 10, 2014 Do you use 64 bit builds? We? We use 64 bit builds. cheers werner Link to comment
sebastianbah Posted March 11, 2014 Share Posted March 11, 2014 Hi nat.harrold,We can't reproduce such behavior, so could you please send us a log file and picture with full grabber settings.It would be very helpful.Thanks! Link to comment
nat.harrold Posted March 13, 2014 Author Share Posted March 13, 2014 Hi Unigine, Here is the information. Let me know if there is anything else that will help your diagnosis. Since 1st post I have updated drivers to latets from nvidia and upgraded the GPU to a 780Ti /3gb Only ever 64bit. Thanks, Nat. log.htm Link to comment
frustum Posted March 13, 2014 Share Posted March 13, 2014 Please reduce the super sampling to 4x. Link to comment
