manuel.gysin Posted February 26, 2014 Share Posted February 26, 2014 Hello We are testing to include Coherent UI framework, this works so far good, but I've read here (https://developer.unigine.com/forum/topic/507-texturegetimage-bug/?p=3051) that getImage should not be used. What are the best practices here? Currently I return from an external class an Unigine::ImagePtr and set it with WidgetSprite::setImage after manipulation was done. Unigine::TexturePtr texture = view->texture; // Access from friend class // Get image Unigine::ImagePtr image = view->image; //Image was created with Unigine::TexturePtr::create2D const size_t singlePixelSize = image->getPixelSize(); const size_t size = _width * _height * singlePixelSize; int* originalSrc = (int*)SharedMemoryHelper::Map(_handle, size); // Set lock image->grab(); glBindTexture(GL_TEXTURE_2D, texture->getGLTextureID()); glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, _width, _height, GL_BGRA, GL_UNSIGNED_BYTE, originalSrc); glBindTexture(GL_TEXTURE_2D, 0); // Release image image->release(); texture->getImage(image); Thanks Manuel Link to comment
ulf.schroeter Posted February 27, 2014 Share Posted February 27, 2014 Hi Manuel, I don't think that there is an alternative in your case. The texture download from GPU to CPU via getImage() should in general be avoided as this is a relatively slow operation and can harm render performance due to GPU stall for required CPU synchronization. But if there is no alternativ: who cares ? Link to comment
manuel.gysin Posted February 27, 2014 Author Share Posted February 27, 2014 Hello Ulf Thanks a lot for your reply. It seems it's the way to go in this case. I was looking through the images class and found the function Unigine::Image::getPixels (Returns the pointer to the array of pixels). But it seems allocated too in the system memory if I understand it right. Link to comment
manuel.gysin Posted February 27, 2014 Author Share Posted February 27, 2014 yep Thanks! Link to comment
