binstream Posted January 30, 2014 Share Posted January 30, 2014 Do you use any IDE (Visual Studio, Eclipse...) to work on UNIGINE-powered projects? If yes, please specify, which one. Link to comment
binstream Posted January 30, 2014 Author Share Posted January 30, 2014 I don't use IDE, my tools are VIM + mc (under Linux). Link to comment
anthony.liot Posted January 30, 2014 Share Posted January 30, 2014 I am using XCode with the Unigine Script on OSX .... But better support for IDE will be really nice, I work with Netbeans too, but never found enough time for have a good support, and Xcode it's always open. On window, I work only with Notepad++, I try to open the less possible visual :) Link to comment
anton.stetz Posted January 30, 2014 Share Posted January 30, 2014 Vim with some plugins under windows Link to comment
aargh Posted January 30, 2014 Share Posted January 30, 2014 I have not found the option "I want to use IDE ..." ;-)Some modern IDE that allows debugging, intellisense, syntax highlighting. Ideally for example as plugin for VisualStudio. Actually i don't use IDE, only PSpad or Notepad++ on Windows. Link to comment
binstream Posted January 30, 2014 Author Share Posted January 30, 2014 I have not found the option "I want to use IDE ..." ;-) Some modern IDE that allows debugging, intellisense, syntax highlighting. Ideally for example as plugin for VisualStudio. Actually i don't use IDE, only PSpad or Notepad++ on Windows. Added "No, but I would like to" option Link to comment
ivan.cuevas Posted January 30, 2014 Share Posted January 30, 2014 Yes, Visual Studio 2012 (plugins: Visual Assist X & Mindscape VS File Explorer) and Notepad++ (under Windows) Link to comment
aargh Posted January 30, 2014 Share Posted January 30, 2014 Thank you. 3 is the clear choice. :rolleyes: Link to comment
martial.barbera Posted January 30, 2014 Share Posted January 30, 2014 I use Notepad++ for unigine script with my own syntax highlighting config-file, but i would like a system for automatic-completion and code syntax validator.(notepad++ plugin will be great) Link to comment
honya Posted January 30, 2014 Share Posted January 30, 2014 I use Visual Studio 2010 for showing syntax highlighting without project/solution. Link to comment
maimonides Posted January 30, 2014 Share Posted January 30, 2014 I use notepad++, but vs plugin would be far better. Link to comment
david.garcia Posted January 31, 2014 Share Posted January 31, 2014 I am using Sublime Text (under Windows and OSX), without plugins. If I got plugins my life would be better. Link to comment
scott.richmond Posted February 1, 2014 Share Posted February 1, 2014 I would love to. Its one of the key reasons Unigine is so far behind every other engine out there in terms of productivity. Link to comment
manuel.gysin Posted February 1, 2014 Share Posted February 1, 2014 I'm using QtCreator. Link to comment
ulf.schroeter Posted February 1, 2014 Share Posted February 1, 2014 Visual Studio Express C++ IDE and notepad++ Link to comment
dai.yuqi Posted February 2, 2014 Share Posted February 2, 2014 notepad++ and Sublime Text 3 Link to comment
ExBemined Posted February 18, 2014 Share Posted February 18, 2014 Using QtCreator here, after testing a few ones this one turned out to be most tolerant to UnigineScript so we have code completion on most classes (with a little help from some defines and the extern info header). Link to comment
danni.coy Posted April 30, 2014 Share Posted April 30, 2014 KDevelop on Linux is the best option I have tried so far. For the most part I have everything I could want except for debugging support. I am trying sublime edit on Windows (for maxscript mostly) but it has the *wrong* shortcuts . I do have some problems with nested namespaces (not a C++ feature) and forloop, foreach and foreachkey structures (also not C++ features) and I do have to reformat the file that you can generate that lists all the built in uniginescript functionality. I could probably post a tutorial on my setup if anybody is interested. Link to comment
anton.stetz Posted April 30, 2014 Share Posted April 30, 2014 KDevelop on Linux is the best option I have tried so far. For the most part I have everything I could want except for debugging support. I am trying sublime edit on Windows (for maxscript mostly) but it has the *wrong* shortcuts . I do have some problems with nested namespaces (not a C++ feature) and forloop, foreach and foreachkey structures (also not C++ features) and I do have to reformat the file that you can generate that lists all the built in uniginescript functionality. I could probably post a tutorial on my setup if anybody is interested. Danny, any information about Unigine is interested. Don't stop)))) Link to comment
angus.wood Posted June 2, 2014 Share Posted June 2, 2014 I use Emacs under cygwin on Windows. If there were to be an IDE I think the biggest thing that would make me use it would be integrated debugging but that's quite a tall order. Link to comment
kadir.basol Posted December 20, 2014 Share Posted December 20, 2014 CLion will be best IDE for C/C++ and ASM i think.I am waiting for stable edition. Link to comment
santosh.a Posted March 2, 2015 Share Posted March 2, 2015 Notepad++ on windows. Being able to work in Visual Studio would be huge help. Link to comment
