christian.shiel Posted January 29, 2014 Share Posted January 29, 2014 Can water be hooked up to wind to create sea conditions? How would I model an ocean conditions for example? Link to comment
christian.shiel Posted January 30, 2014 Author Share Posted January 30, 2014 I guess what I'm asking is, is this something that can work out of the box or will this require lots of extra scripting? Link to comment
sebastianbah Posted February 4, 2014 Share Posted February 4, 2014 Hello, You can change sea conditions by materials change or you can modify the following material parameters (water_base material): - Materials -> Parameters -> Transform -> Normal 0 - Normal 3 - Materials -> Parameters -> Reflection -> Normal Some customized materials you can find in SDK samples.From the SDK browser: Samples & Demos tab -> Cool Material library -> ocean_* samples. Link to comment
