christophe.meurice Posted January 23, 2014 Share Posted January 23, 2014 Hi ! I have a problem with a recursive function that receive an integer as reference parameter. I increment this integer in the function then when I return, I'm expecting the value to be incremented but no, it's the old value. When I call an other function (not recursive), it works ok the value after the return is incremented. A sample code : 'foo' is the recursive function 'bar' is an other function Look at the 'After recurse' log line void foo(int &a) { if (a == 5) return; log.message("Start : %d",a); a++; log.message("Incremented : %d",a); foo(a); log.message("After recurse : %d",a); if( a == 1){ bar(a); log.message("After Bar incremented : %d", a); } } void bar(int &a) { log.message("Bar : %d", a); a++; log.message("Bar incremented : %d", a); } Output : 10:52:59 Start : 0 10:52:59 Incremented : 1 10:52:59 Start : 1 10:52:59 Incremented : 2 10:52:59 Start : 2 10:52:59 Incremented : 3 10:52:59 Start : 3 10:52:59 Incremented : 4 10:52:59 Start : 4 10:52:59 Incremented : 5 10:52:59 After recurse : 5 10:52:59 After recurse : 4 10:52:59 After recurse : 3 10:52:59 After recurse : 2 10:52:59 After recurse : 1 10:52:59 Bar : 1 10:52:59 Bar incremented : 2 10:52:59 After Bar incremented : 2 Expected output : 10:52:59 Start : 0 10:52:59 Incremented : 1 10:52:59 Start : 1 10:52:59 Incremented : 2 10:52:59 Start : 2 10:52:59 Incremented : 3 10:52:59 Start : 3 10:52:59 Incremented : 4 10:52:59 Start : 4 10:52:59 Incremented : 5 10:52:59 After recurse : 5 10:52:59 After recurse : 5 10:52:59 After recurse : 5 10:52:59 After recurse : 5 10:52:59 After recurse : 5 Thanks for your help Link to comment
christophe.meurice Posted January 23, 2014 Author Share Posted January 23, 2014 Forgot to tell that I call only foo() like this : int i=0; foo(i); But I have some update : Passing a class as reference to a recursive function works great ... I've implemented a class like that one : class Idx{ int m_i; Idx(){ m_i = 0; } Idx(int i){ m_i = i; } void inc(){ m_i = m_i+1; } void inc(int i){ m_i = m_i + 1; } int val(){ return m_i; } }; I've replaced my int by that class and it works great. That's a work around but I think that the posibility to use primitive types is better. Any idea ? Link to comment
ulf.schroeter Posted January 23, 2014 Share Posted January 23, 2014 Seems to be a bug Link to comment
silent Posted January 24, 2014 Share Posted January 24, 2014 Hi, Thank you for this information! This issue was passed to the developers. I'm afraid at this moment issue have lowest priority. If it acceptable in your case, you can use simple workaround to achieve correct results, but without passing argument as reference: int a; void foo() { if(a == 5) return; log.message("Start : %d\n",a); a++; log.message("Incremented : %d\n",a); foo(); log.message("After recurse : %d\n",a); if(a == 1) { bar(); log.message("After Bar incremented : %d\n",a); } } void bar() { log.message("Bar : %d\n",a); a++; log.message("Bar incremented : %d\n",a); } int a = 0; foo(); Sorry for the inconvenience caused. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
ulf.schroeter Posted January 24, 2014 Share Posted January 24, 2014 I'm afraid at this moment issue have lowest priority. Wow, a fundamental UNIGINE script language feature bug having the potential to screw all kinds of customer code calculations = lowest priority ????!!?? Sorry to say that, but you really should rethink this. Such kind of fundamental errors ( a+1 = a, that's what we are facing here...) ALWAYS must have the highest priority or something is wrong with prioritization.... Link to comment
binstream Posted January 24, 2014 Share Posted January 24, 2014 Ulf, don't worry - it's already fixed =) Link to comment
christophe.meurice Posted January 24, 2014 Author Share Posted January 24, 2014 Tks for the fix ;) Link to comment
ulf.schroeter Posted January 24, 2014 Share Posted January 24, 2014 Ulf, don't worry - it's already fixed =) Hi Denis, this is exactly the answer I was expecting :) Link to comment
