[SOLVED] node file : surface id
We are generated on server side Unigine node with automatic generated mesh, unfortunately, we have some problem with settings surface name inside node file, do you know if will be possible to specify an id surface inside the node file ??
Like we have generated this :
<node type="ObjectMesh" id="7046" name="Only_for_the_Brave">
  <mesh>6099_2.mesh</mesh>
  <surface name="17407_private_sku" intersection="0" collision="0" viewport_mask="2" collision_mask="2" material="17407_private_sku" property="surface_base"/>
  <transform>1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1</transform>
</node>
But will be better to have something like :
  <surface id="0" intersection="0" collision="0" viewport_mask="2" collision_mask="2" material="17407_private_sku" property="surface_base"/> <-- We want this material on the surface 0 of the mesh
</node>
Thanks
Tony
Hi Anthony,
No ids, sorry. However, you can add custom arguments such as 'tag' or 'id' and parse it manually on client side to assign proper materials. Also, you can count that surfaces described in node file are in strict order as they are placed in the mesh.
Cool!
Also you can create something like surface map and place it near node file. This will reduce warnings in console about 'unused argument'. Please write here if you get some results. :)
Hi Andrey, I just try other things and it's work.
I have the id of my surface in BD, and I have access to the mesh file too, I quickly write in php a mesh header reader and how the first byte contains the num of surfaces and their name, was easy to change my id by the real name...
Tony
