Chen.Gaowei Posted May 24, 2013 Share Posted May 24, 2013 Hi, There is a bug when pressing the scaling button on the nodes panel (N) of the editor. I increase the scaling value up to 2 digits, it does not function correctly anymore. Can you verify this bug? You can check the attached picture to see what I am describling. Pressing the button does not work when the value reaches 10.0 Thanks! Link to comment
silent Posted May 24, 2013 Share Posted May 24, 2013 Hi, I'm afraid this is correct behavior. If you want to set scale more then 10 you can set it manually by editing the text fields. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Chen.Gaowei Posted May 27, 2013 Author Share Posted May 27, 2013 Hi, I'm afraid this is correct behavior. If you want to set scale more then 10 you can set it manually by editing the text fields. Thanks! Ok, so is there a way to set to allow scale more than 10 using the button. Link to comment
silent Posted May 27, 2013 Share Posted May 27, 2013 is there a way to set to allow scale more than 10 using the button. You can modify <SDK>\data\core\editor\editor_nodes.ui file and change default maximum limit of scale fields. Please, found these strings: Nodes::scale_sb[0]" export="1" min="0" max="100" Nodes::scale_sb[1]" export="1" min="0" max="100" Nodes::scale_sb[2]" export="1" min="0" max="100" and replace max="100" to max="1000". Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Chen.Gaowei Posted May 28, 2013 Author Share Posted May 28, 2013 You can modify <SDK>\data\core\editor\editor_nodes.ui file and change default maximum limit of scale fields. Please, found these strings: Nodes::scale_sb[0]" export="1" min="0" max="100" Nodes::scale_sb[1]" export="1" min="0" max="100" Nodes::scale_sb[2]" export="1" min="0" max="100" and replace max="100" to max="1000". Thanks! ok, thanks Link to comment
