ulf.schroeter Posted November 22, 2010 Share Posted November 22, 2010 Problem Soft LOD fading does not seem to work when setting surface min/max parent to 0 for surface individual distance fading. In this case surfaces just appear/disappear without fade transition (see road surfaces in test case) Soft LOD fade happens when setting surfaces Min/Max parent to 1, but then of course all surfaces fade in/out at the same parent-relative distance. MeshFade.zip Link to comment
frustum Posted November 23, 2010 Share Posted November 23, 2010 I know this issue. Soft fade LODs can't work with non 1 LOD parents now. I will fix this bug only for symmetry min/max surface parents. In next update. samples/objects/lods_3 will shows this technique. Link to comment
ulf.schroeter Posted November 23, 2010 Author Share Posted November 23, 2010 I know this issue. Soft fade LODs can't work with non 1 LOD parents now. I will fix this bug only for symmetry min/max surface parents. In next update. samples/objects/lods_3 will shows this technique. ok, but there might be also a fade problem for symmetry min/max = 1 LOD parent, as you can see on the attached screenshot. Please try to reproduce problem with the provided test case and following steps. set LOD min/max parents for all road surfaces to 1 Focus camera on road top level node to set camera rotation pivot to center of geometry zoom in until road network is visible/fading in rotate around geometry pivot From different camera positions different fade levels are visible, but I would expect more or less constant fade level as camera distance should be the same when rotating around parent pivot (screenshots taken from opposite view directions). Link to comment
frustum Posted November 24, 2010 Share Posted November 24, 2010 0-3 screens use fading based on surface distance (0 min/max parents) 4-6 screens use fading based on node distance (1 min/max parents) Both variants work ok now. Link to comment
ulf.schroeter Posted November 24, 2010 Author Share Posted November 24, 2010 Both variants work ok now. Very good ! Link to comment
