pascal.winistoerfer Posted November 21, 2010 Share Posted November 21, 2010 Hi Guys I have 2 Bugs to Report First: Mesh Position in Node Reference Edit changes it's values from itself Second: If you hit APPLY CHANGES after adding the Meshes to the Reference, it doesn't overtake the new meshes in the node - they are even not here anymore if you edit the reference again. First is Explained in the Screenshots at the bottom, Second is self explaining. First: 1 Mesh Position in Node 2 Adding an additional Mesh into the Node 3 Moving the Node around a little bit 4 New Mesh Position of the Mesh that was in the Node before i hit Edit Reference 5 adding some more Meshes and Moving them a little bit around 6 New Mesh Position of the Mesh that was in the Node before i hit Edit Reference Link to comment
serega Posted November 22, 2010 Share Posted November 22, 2010 Can't reproduce the first bug with my meshes and nodes. Can you send us your mesh and node with house and door? Link to comment
pascal.winistoerfer Posted November 22, 2010 Author Share Posted November 22, 2010 Can't reproduce the first bug with my meshes and nodes. Can you send us your mesh and node with house and door? Sure, send me a PN with your mail or should i mail Denis? Link to comment
serega Posted November 23, 2010 Share Posted November 23, 2010 support@unigine.com :) Link to comment
