anthony.liot Posted April 16, 2013 Share Posted April 16, 2013 Hi, I have some mesh inside zip, and i want create Mesh using the data (unsigned char*) i have with the zip->readFile method, but apparently GLMesh can load only from file.There is a way to do this without write the file on the HDD passing directly the data to my GLMesh.Thanks Link to comment
frustum Posted April 16, 2013 Share Posted April 16, 2013 Engine overrides a base File class. You have to create same class substitution. Or much simple solution is to use buffered files [script]: string name = "temp.mesh"; engine.filesystem.addBufferFile(name); File file = new File(); if(file.open(name,"wb")) { // write data into file file.close(); } delete file; // load mesh from file ObjectMesh mesh = new ObjectMesh(name); engine.filesystem.removeBufferFile(name); Link to comment
