tristan.brett Posted April 3, 2013 Share Posted April 3, 2013 When I export my mesh from max it appears fine in engine. When I export as node I get errors saying can't load .mat, can't load .mesh. I have tried all of the different settings in the node export tool with no success... Link to comment
necris Posted April 4, 2013 Share Posted April 4, 2013 Tristan, Such problem might happen if you enter wrong Path Prefix value in "node exporter" options. Note: Path Prefix should specify the path to a folder where .node file will be saved (relative to <UnigineSDK>/data directory) If this advice doesn't help you - please send us more information about problem: - 3ds max version - 32/64 bit - example of exact settings, which you used for export Link to comment
