honya Posted March 3, 2013 Share Posted March 3, 2013 Hi, i try set animation file for the skinner.animation from the script. In the script i use schemer.input and skinner.animation and code for set is: (inputName = Event_Jump_Anim ; value = asset_library/characters/horseman/animations/horse/horse_jump.sanim ) Unigine::Skinner::SkinnerMesh skinnerMesh; void setSkinnerInputString(string inputName, string value) { int inputId = skinnerMesh.getInputID(inputName); if (inputId != -1) { skinnerMesh.setInput(inputId, value); } else { log.warning("Unknow Skinner Input: " + inputName); } } but it not working, so what i do wrong? Or i must do it another way to set it? Thank for reply Honya Link to comment
manguste Posted March 5, 2013 Share Posted March 5, 2013 Jan, The thing is Skinner in its blocks caches animations it uses by their ID, since caching allows for faster work. What you need to do is customize the blocks you use to dynamically change the animation. For that, edit data/core/systems/skinner/blocks/. Link to comment
honya Posted March 5, 2013 Author Share Posted March 5, 2013 Manguste, thanks for your reply. I will modify it for us purpose. Honya Link to comment
