pramod.s Posted December 6, 2012 Share Posted December 6, 2012 Hi, I have developed a circle using a dynamic mesh by adding lines to the specified number of vertices. I am trying to find a way to increase the width of the line, but unable to find solution. Can anyone help me in increasing the Line width for an dynamic mesh. Below are the step I do to create the dynamic mesh. meshObj = new ObjectMeshDynamic(); meshObj.setSurfaceMode( OBJECT_MESH_DYNAMIC_MODE_LINES, 0 ); meshObj.setMaterial(material, "*"); meshObj.setProperty("surface_base", "*"); meshObj.addLineStrip(numVertices); forloop(int i = 0; numVertices) { //Calculate my circle logic and replace i value meshObj.addVertex(i); } meshObj.updateBounds(); meshObj.flush(); Now I need some way to increase the width of this line, as my dynamic object is place very far & I am not able to see the line of this circle. Link to comment
ulf.schroeter Posted December 6, 2012 Share Posted December 6, 2012 Just specifiying MODE_LINES is not enough to draw lines, this just influences how vertices and adjencency information will passed to the geometry shader. If you want to draw lines on DX10+ HW than have a look at UNIGINE sample data/samples/shaders/lines_00 to draw lines of the arbitrary width using a geometry shader. If you have just DX9 HW than you have to provide "real" triangle strip mesh geometry even for thin line drawing. See this post for an example. 1 Link to comment
