Can not set spline name while editing WorldTransform
In tab transform spline name is always empty. It causes spline unloading when one try to switch tabs (to node tab for example) and may be in some other cases. Anyway it very difficult to edit WorldTransform.
Solution.
Change code in function WorldTransform::create (file: core/editor/editor_creator_worlds.h, line 429)
Original:
void create() {
	if(dialog_creator("WorldTransform parameters")) {
		Node node = NULL;
		if(transform_tab.isCurrentTab()) {
			if(dialogFileSpline("Select spline to load",transform_name) == 0) return;
			node = new WorldTransform();
			if(WorldTransform(node).load(transform_name) == 0) {
				dialogMessage("Error");
				delete node;
				return;
			WorldTransform(node).setRadius(transform_radius.value);
			node = class_remove(node);
		else if(transform_bone_tab.isCurrentTab()) {
			node = class_remove(new WorldTransformBone(transform_bone_bone.value));
			WorldTransformBone(node).setRadius(transform_bone_radius.value);
		else {
			throw("WorldTransformBone::create(): unknown transform\n");
		set_node(node,"core/editor/gui/world_transform.png");
Modified:
void create() {
		Node node = NULL;
				delete node;
				return;
			WorldTransform(node).setSplineName(transform_name); //fixes bug
		else {
