anthony.liot Posted September 17, 2012 Share Posted September 17, 2012 HI i have some problems with japanese character when i want use plugin in unigine. The cfg file contains the good character but not the plugin path. 02:13:28 Xml::load(): can't open "C:/Documents and Settings/寿恵/Application Data/OnlineActiViewer/bin/unigine.cfg" file 02:13:28 Config::load(): can't open "C:/Documents and Settings/寿恵/Application Data/OnlineActiViewer/bin/unigine.cfg" file 02:13:28 Loading "C:/Documents and Settings/��b/Application Data/OnlineActiViewer/lib/PlayerPlug.dll"... 02:13:28 EnginePlugins::addPlugin(): can't load "C:/Documents and Settings/��b/Application Data/OnlineActiViewer/lib/PlayerPlug.dll" library 126 02:13:28 Engine::init(): can't initialize filesystem Link to comment
frustum Posted September 18, 2012 Share Posted September 18, 2012 Can't reproduce the problem under Windows 7 with "D:\寿恵\Interface_x86d.dll" plugin path. Link to comment
anthony.liot Posted September 18, 2012 Author Share Posted September 18, 2012 Sorry it's seems my problems is before when i launch unigine i launch with -extern_plugin but the path is wrong. I give the wrong path with bad encoding. Link to comment
