mateusz.kloszczyk Posted September 14, 2012 Share Posted September 14, 2012 WidgetSprite is rendered not on the ObjectGui surface but moved to rear in 3D space. It happens only if WidgetSprite is loaded from .ui file. If it's created from scripts - it works ok. Other widgets works ok even loaded from .ui. objectguitest.zip Link to comment
frustum Posted September 14, 2012 Share Posted September 14, 2012 Thanks for the report. The problem has been fixed. Link to comment
