Rob Posted August 29, 2012 Share Posted August 29, 2012 It would be great if you had more control over each channel, at the moment you can use grass to create 4 different plants by using the 4 channels and a texture with 4 columns but the density for all these plants is the same, so it would be better if you could set the density for each channel individually Link to comment
manguste Posted September 13, 2012 Share Posted September 13, 2012 Ok, we'll check if it can be implemented. Link to comment
Rob Posted September 13, 2012 Author Share Posted September 13, 2012 Thats great! Hope it will be possible Link to comment
Rob Posted November 22, 2012 Author Share Posted November 22, 2012 Great thank you so much! Link to comment
