Rob Posted August 28, 2012 Share Posted August 28, 2012 I was looking into the Unigine demos and noticed every tree thats created uses 2 materials, the stem and leaves even the palm trees in tropics are created this way Is there a reason for this? Isnt it better to use just 1 material for better performance? Link to comment
ulf.schroeter Posted August 28, 2012 Share Posted August 28, 2012 depending on vegetation type mesh_leaf_base provides things like camera facing billboards, alpha testing etc which is not required for the stems. Also separation of leafs and stems allow better texture detail for both parts. In principle lower material counts provide better performance, but don't be too strict with this rule. 2 materials for high detail trees is no problem. Nevertheless usage of things like texture atlas for thousands of far away low-detail trees is still a good thing. Link to comment
demostenes Posted August 28, 2012 Share Posted August 28, 2012 Some time ago I was doing following test on other engine. Two materials for tree (bumped+diffuse for bark, transparent for leaves), vs one material (transparent for both + alfa mask for bark). There was very small difference in performance, which can be considered statistical error. And I agree, that having two materials is far more flexibile. Link to comment
Rob Posted August 28, 2012 Author Share Posted August 28, 2012 Oke thanks for the answers, will leave my palm with just one texture as it is then but definately see the point of using 2 textures with normal trees with regular leafs Link to comment
