[SOLVED] Keyline window problem
Hello.
I have noticed a problem on Keyline window.
Lets say I want to change some lighting parameters and observe the result in run time.
So i go in tropics, I press the environemnt button and then the edit button. I change the sliders and then when i
click the screen to look around. after that i cant use the mouse anymore cause the Esc doesn't make the mouse
reappear.
How can i change the mouse functionality in unigine ? I want it to dissappear only if it is pressed.
thnx.
Yes, you are right, thank you for pointing it out. Submitted to developers, though with minor status, I'm afraid. The keyline system can be replaced with Tracker system, so we encourage you to use the latter instead.
  • 3 weeks later...
Aside from using Tracker (it's much better solution in all aspects), you can disable grabbing of the mouse completely. For that you need to remove MOUSE_SOFT define from a system script.
