ulf.schroeter Posted July 23, 2012 Share Posted July 23, 2012 File System documentation only states warning Warning All filenames inside pack files are case sensitive! This is especially dangerous in Windows since being unpacked files are processed case independent (according to the OS behavior). If you have errors while opening files from packs, check filename case first. But it seems that also usage of '\' within filepath specifications (working with regular file directory under Windows) leads to errors when file structure is packed within UNG archive. In this case consistent usage of '/' file path separator characters solves the problem. Proposal Additional warning to use '/' characters for resource file path specifications to avoid problems when packed in UNG archives. Link to comment
frustum Posted July 24, 2012 Share Posted July 24, 2012 The problem with \ and / slashes has been fixed. Link to comment
ulf.schroeter Posted July 24, 2012 Author Share Posted July 24, 2012 yep, even better Link to comment
