[SOLVED] set the font of engine.visualizer.renderMessage function
Hi all:
I need to render message in chinese, I know the GUI have
function to set a font and render chinese text, but how to do this
use engine.visualizer? how to set the font to be used in
engine.visualizer.renderMessage2D/3D function?
I look around and didn't find any function to do this.
and another question:
Does engine.visualizer.renderMessage3D function have better perfermance
and run efficiency than Object_GUI + WidgetLable for display large number of place names?
please give some suggestions, thanks in advance!
You can change a font that is used by default for your custom one: it's <UnigineSDK>/data/core/gui/font.ttf.
Our devs say both should be pretty much the same from performance point of view. What they did advise is to check where the player is and do not render names outside some radius around it (for example, disable all messages that are further than 100 meters). And additionally check if they are visible in the view frustum. This will allow to keep performance up even in case of many place names.
