GeorgeP Posted May 16, 2012 Share Posted May 16, 2012 Hello.I face a problem concerning the world direction of an object.I create a box using the create_box function in primiives.hI set the world direction to 0,0,-1.After 1-2 updates, the world direction becomes 0,0,-1 even though i dsont change it.Here is the code of the object. class DummyObject { Object object; DummyObject(Vec3 position) { object = create_box(vec3(1.0f),0,translate(position)); object.setWorldDirection(vec3_zero); log.message("initial direction: " + object.getWorldDirection() + "\n"); } ~DummyObject() {} void update() { vec3 position = object.getWorldPosition(); log.message("World direction: " + object.getWorldDirection() + "\n"); position += object.getWorldDirection(); object.setWorldTransform(translate(position)); } }; and here is the output:Why does the direction change without calling any setWorldDirection to the specific object?Thank you. Link to comment
Guest anet Posted May 17, 2012 Share Posted May 17, 2012 Direction vector can't be a vec3_zero. It is always a vector with unit length. Thus, when you try to set vec3_zero as an object direction, engine calculates new transformation for it. And apparently it becomes default direction vector: (0,0,-1) Link to comment
manguste Posted May 23, 2012 Share Posted May 23, 2012 Added a note on that into docs. Link to comment
