[SOLVED] GUI - GetWidth / GetHeight
Hello guys,
i attached an example with my problem, in a shutnell:
I'm creating an dynamlicy gui, without using an ".ui" file, so all is done in code behind, now i want to add a sprite, and at this point i hit the actual problem.
My sprite should overlay the WidgetTabBox, in this we create the dynamic widgetelements, so after i run through my initialize method, the WidgetTabBox.getHeight and .getWidth are "0".
So i cant set my width and height to my spritelement.
The only thing which i can do, to set in the "update" function the setWidth and setHeight action for my sprite (but thats not nice to handle...).
So i / we would need an event-trigger which creates the gui, or can set a function after the trigger was runned, or an function where i can overgive my Container and this function would count together which "height" and which "size" the element have.
I hope u understand.
The demo should explain the problem easier.
Greetings
Lars
ui_layout.zip
Hey Lars,
You should call Widget::arrange() method if you want to get any sizes before first widget update.
Just add this lines in init function:
mainTabBox.arrange();
sprite.setWidth(mainTabBox.getWidth());
sprite.setHeight(mainTabBox.getHeight());
